Author Topic: TBS board again???  (Read 24840 times)
Offline gordyzx9r
  • The Sultan of Swank
Re: TBS board again???
« Reply #60 on: January 11 2011, 03:20:10 PM »
Quote from: "ULYCYC @ Tue Jan 11, 2011 2:37 pm"
Quote from: "DCEPTCN @ Mon Jan 10, 2011 9:27 pm"
Could someone enlighten me as to what he might be referencing when he says that the negativity may have driven him off?
I won't go into details but he didn't like it when we subjected him to the same critizism we would hang onto any other product or vendor. Snakeoil is snakeoil.
Mike gave it hard to others and got pissed when he was called out by some of the senior guru's.
Is this about the stock alternator amperage versus his alternators amperage?
« Reply #61 on: January 11 2011, 03:26:46 PM »
Quote from: "gordyzx9r @ Tue Jan 11, 2011 3:20 pm"
More or less. Also the real need for 200+ amps.  The stock alt or the 140amp alt will handle 99% of all needs for our cars.  This statement cut into his claims. Also he was confused by engine speed (crank pulley) and alt shaft speed.
TBS board again???
« Reply #62 on: January 11 2011, 03:54:33 PM »
To add to what I posted above. I won't be part of a Americian or Canadian owned corporate board. Why should I spill out my 45 yrs of automotive knowledge for free so they can make money. I do it for free and will do it here or by email or on the phone.
TBS board again???
« Reply #63 on: January 11 2011, 04:25:40 PM »
As Ed stated, Mike made several claims regarding alternator performance that were pure b.s. from a technical stance and was called on them.
At the time, it was not known he was the force behind PowerBastards alternators, but, a little research into complaints filed with the BBB as well as on other forums turned up his ownership.
It was clear that despite his claims to not being a vendor, he was.  He did not appreciate his technical statements being disproved and stomped off.
He ran a good board for a number of years, and, it will be missed.
Like Ed, whatever little I know is available to anyone that I can help without charge.
TBS board again???
« Reply #64 on: January 11 2011, 04:40:22 PM »
Damn - I have one of his 200A upgrade kits in my TR. Should I worry?
Also - I am VERY honored to have such tech talent posting here!
TBS board again???
« Reply #65 on: January 11 2011, 04:49:02 PM »
Quote from: "SuperSix @ Tue Jan 11, 2011 4:40 pm"
Thank you
No real problem with the quality that I know of. You just can add a 5000 watt amp and weld fences now :rolleyes:
Offline Ttype83
« Reply #66 on: January 11 2011, 05:01:01 PM »
I need some welding done... I'm on my way over.  :supz:
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
DCEPTCN
  • Guest
« Reply #67 on: January 11 2011, 09:18:18 PM »
My car is sans Savino since I busted the starter I bought from him while pulling the motor. Bad Sylvan.
TBS board again???
« Reply #68 on: January 11 2011, 09:26:45 PM »
Quote from: "ULYCYC @ Tue Jan 11, 2011 4:49 pm"
Thank you
Car still has flaky voltage output at idle - did before I did the upgrade.
Offline gordyzx9r
TBS board again???
« Reply #69 on: January 11 2011, 09:28:44 PM »
Me too...and a mini-starter.  On the Scanmaster, I did notice an increase in voltage though...but the alternator that was replaced was the stock one and I also had all new Casper battery cables put in too.
What was funny was when I had someone replace my fuel pump and do a couple of other things.  They told me it would be a good idea to put on a Red's Volt Booster...Stev e had allot of great things to say about that (I've since removed it).
Offline gbsean
« Reply #70 on: January 11 2011, 09:42:53 PM »
have had no issues with his mini starter...had a 200amp unit that flaked out asked if I could have him fix it...no response ...oh well nice guy got 240 unit only to find out I needed a new serpentine belt...would of been nice to have a heads upon that...there were a few posts that we...Ed SW myself called him out on....tha Alt sticks out like a sore thumb...the other was a ground issue he had with his RX7...oh well I have SW and Eds home # so I can call anytime...lol
TBS board again???
« Reply #71 on: January 11 2011, 11:11:25 PM »
I bought a couple of mini starters...the y are cheap imports...they work okay, but there is a piece of plastic in them that breaks and renders them inoperative with a backfire.
The alternators are just imported parts like many that we see sold everywhere.  The simple fact is that, as Ed pointed out, very few need more amps....as long as your amp is capable of putting out 13.5v with everything going while driving, then it has plenty of power.
Remember, the scantool does not necessarily reflect the voltage being supplied by the alternator...a nd, that as an alternator gets old, it may not supply as much as it did originally because the diodes are old and have been subjected to heat for years...does not mean you need a bigger one, just that the old one is getting tired.
Need to write a bit for the tech section on the subject, I think
« Reply #72 on: January 12 2011, 02:42:45 AM »
Steve, when you write your tech section, figure in why anybody even wants a 200A alternator. Rear window defroster(so when we drive these cars in the snow), mini starter ( which uses gear reduction to an advantage) and 7,000lb lnjectors (to go really fucking fast) and than I will understand the major load requirements. Oh, and a boom box.
« Reply #73 on: January 12 2011, 08:06:37 AM »
I did a major alternaror writeup for Steve site but it's still in the proofread and shorten stage.  As Steve said maybe it's time to twaek it and get it posted.
On another note if you did have a system that needed all that amperage his CS130 base cases are too small and will self-destruct over a short time. That is why you see high amperage units with big heat sink vented cases for double the price. Pulling a max of around 85amps out of a typical Buick won't tax his small case unit.
Offline 87granny
« Reply #74 on: January 12 2011, 08:09:21 AM »
Quote from: "Pyro6 @ Wed Jan 12, 2011 2:42 am"
Yea and a generator hook up to power your house when the power transformer get's hit by a car
