Author Topic: Drag shocks  (Read 19219 times)
Offline Turbo Archie
Drag shocks
« on: August 08 2005, 10:57:04 AM »
I just installed some comp drag shocks.
The rears would compress to fast and unload the rear on launchs (bounce). The front would not open (rise) when I tried with my hands. So both shocks were not doing what I needed and I hope the new shocks will show some good 60's.
The best I got before was a high 1.68 with the avg being 1.78.
I need 1.55's .
I was going to the track on tuesday but it might rain.
We have a nother street race at the track on thursday and I'm going to race a turbo TPI TA.
I also think I have my fuel curve figured out, the car should run a little faster.
Offline Recklessrob
Re: Drag shocks
« Reply #1 on: August 08 2005, 12:41:21 PM »
Those should make a difference. Ironically, I've had
good luck with off the shelf cheap shocks. They seem a little
weaker and respond fairly quick.
Rob
Offline 87natty
Drag shocks
« Reply #2 on: August 08 2005, 03:58:53 PM »
What are your rates on the shocks? Usually you only need to do the fronts, I've had good long with worn out rear shocks myself.
Drag shocks
« Reply #3 on: August 08 2005, 06:08:13 PM »
90/10 and 50/50
Thats the problem, I need something a little stiffr that will push against the tires. Hard to explain but when I see the video, the rear of the car comes down hard and bounces back up, unloading the tires.
Leaving off a brake, right bag with 20#
I really think this will help.
Re: Drag shocks
« Reply #4 on: August 09 2005, 09:55:33 AM »
Looks like no rain, so I should make it tonight. Hot though at 93 deg.
Who wants to guess my 60' ???
Offline 87natty
Drag shocks
« Reply #5 on: August 09 2005, 03:16:23 PM »
1.8? We should start a pool.
I see what you're saying, something with a harsh rebound to slow the body on it's way up. Have you done anything to the control arms?
Drag shocks
« Reply #6 on: August 09 2005, 05:07:19 PM »
Stock noodles
I'm going with a 1.62
Drag shocks
« Reply #7 on: August 13 2005, 06:03:04 PM »
Ok, alittle off.
but very consistant 1.70 - 1.71 and felt very smoth, so now I need more power.
Small set back. The car ran for shit. I seemed to get worse, only made 3 runs.
Did a compression test and have 1 bad cyl with a weak second cyl. Now I need to figure out if it's a broke ring, or just a weak ring/cyl wall.
Re: Drag shocks
« Reply #8 on: August 27 2005, 03:25:16 PM »
**Update
I think I smoked 3rd. No?
