Author Topic: Powermaster  (Read 6524 times)
Offline Jordan_J
Powermaster
« on: December 19 2010, 02:41:36 PM »
After doing my hydroboost conversion I now have a powermaster I don't need. What do they run for used? Remans run like $600.
87 Turbo T - 4.1 484 block bored .030 over, Champion ported irons with ported intake, RJC power plate, Elgin 214/224 cam, 6776 turbo with RJC boost controller, stretched SLIC, 3\" THDP, Pypes dual exhaust, 4\" MAF pipe with 14\" K&N and Z06 MAF, 60# Mototrons, hot wired Walbro 340 with KB-BAP, Translator Gen 2 and Extender Extreme chip, Mike Kurtz built 200-4r, PPC 3200 stall, UMI upper and lower control arms, passenger side airbag, any hydroboosted.
20# Boost at 20* timing on 93 octane. No track times yet.
Alky install in progress.
Offline TRICKSIXPA
  • Shiny Parts Addict!
Re: Powermaster
« Reply #1 on: December 19 2010, 03:44:48 PM »
Well for a good working one $150 to $200 also depends if there is a newer acumulator ball to it.
Stefan
Offline 2 FILIP
Re: Powermaster
« Reply #2 on: December 20 2010, 11:45:53 AM »
I've bought used powermasters for $75, 125 an 175 before... hate them so much. How much do you want for yours?
I'm a glutton for punishment... LOL! :rolleyes:
1987 Buick Grand National, 60k miles, black, TA49, 50lb injectors, Terry Houston DP, SMC alcohol injection
2003 Pontiac Grand Prix GTP, 90k miles, silver, ZZP downpipe, thrasher 3.4 pulley, wizaired intake
2007 Ford F150 SuperCrew, 100k miles, brown, Magnuson TwinScrew supercharger, 40lb injectors
Offline Jordan_J
Re: Powermaster
« Reply #3 on: December 20 2010, 12:07:10 PM »
I was thinking $125 shipped or something. It worked fine for me you can just tell it's old and used.
Powermaster
« Reply #4 on: December 26 2010, 07:29:14 PM »
I converted to vacuum and love it.
Why did you replace the Powermaster?
I think the accumulator ball (if it's still fully charged and in good shape) may be worth more than the rest of the unit.
Offline Jordan_J
Re: Powermaster
« Reply #5 on: December 27 2010, 03:19:01 PM »
Well I wanted brakes I knew wouldn't go out when I potentially needed them. I also don't have a transbrake and always foot brake to launch so I wanted to hold more boost. I heard hydroboost were the best for that. I was going to get vacuum until I learned about the hydros.
Powermaster
« Reply #6 on: December 27 2010, 04:20:54 PM »
Makes sense. How hard was the swap? I don't race (lately) so I don't need to worry about holding boost.
Offline gordyzx9r
  • The Sultan of Swank
Re: Powermaster
« Reply #7 on: December 27 2010, 06:24:00 PM »
For awhile Accumulator balls were fetching upwards of $300 for NOS...but now that Kirban's is selling them for $180 the prices have come down.
Offline Jordan_J
Powermaster
« Reply #8 on: December 28 2010, 11:27:57 AM »
Quote from: "SuperSix @ Mon Dec 27, 2010 4:20 pm"
It's a pretty easy swap. The four bolts under the dash were the hardest and they weren't very hard just time consuming to take off. All the rest is easily accessible especially since I was changing my PS pump and A/C compressor anyways. With the giant hole in that area it was just a matter of reconnecting the PS lines a different way.
Powermaster
« Reply #9 on: December 28 2010, 11:39:35 AM »
Do you have to change the pedal assembly too? That part really sucked.
Offline Jordan_J
Re: Powermaster
« Reply #10 on: December 29 2010, 09:46:19 PM »
Nope, I just pulled the hair pin and washer off and after the powermaster was out I had my brother angle it towards the passenger side of the car and slid the pedal off and it swapped right over.
