Author Topic: If your cam sensor was bad what would it do to hurt your car?  (Read 5899 times)
Offline Be4u
If your cam sensor was bad or out of whack what would it do to hurt your car?
Save the bumper fillers!
Move to Canadia!
Offline JP87GN
Re: If your cam sensor was bad what would it do to hurt your car?
« Reply #1 on: July 21 2005, 12:44:16 AM »
Read up on this. http://gnttype.org/techarea/ecmsensors/camsensor_FAQ.html  If its bad I don't think the car will start.
86 T-Type daily driver
Offline Recklessrob
« Reply #2 on: July 21 2005, 01:40:26 AM »
Caspers sells a tool/module that plugs into the car's engine harness
that sends a false signal to the ecm so you can start the car, if the
cam sensor craps out.
Rob
« Reply #3 on: July 21 2005, 09:32:27 AM »
Quote from: "Recklessrob @ Thu Jul 21, 2005 12:40 am"
They also sell an alignment tool which makes it MUCH easier to set it initially.
Pretty awesome piece..
https://www.casperselectronics.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=107112
Offline Be4u
« Reply #4 on: July 21 2005, 09:46:09 AM »
S6, do you leave that piece on the car or do you use it then put your old one back on?
Move to Canadia!
« Reply #5 on: July 21 2005, 09:50:33 AM »
Quote from: "Be4u @ Thu Jul 21, 2005 8:46 am"
Stays on..
Offline Be4u
« Reply #6 on: July 21 2005, 10:21:22 AM »
Sweet! Thanks for pointing that out ot me!
Move to Canadia!
