Author Topic: turbo oil feed line  (Read 8680 times)
Offline Be4u
turbo oil feed line
« on: July 16 2005, 06:29:32 PM »
Sitting here looking at my oil feed line to the turbo I noticed it comes pretty close to the header AND header heat shield. The line is stock. Would that cause c
Save the bumper fillers!
Move to Canadia!
Offline Recklessrob
Re: turbo oil feed line
« Reply #1 on: July 17 2005, 01:18:58 AM »
You could wrap the line in some of that woven fiberglass
sleeving that Summit sells for ignition wires and stuff. :idea;
Rob
Offline JP87GN
« Reply #2 on: July 17 2005, 01:07:47 PM »
To remove yours just find a wrench or adjustable wrench to fit the square part of the sensor block and hold it while you bust the line loose. The white jiz is just teflon thread sealer and you can use teflon tape, Its a tapered flare fit so it should not leak.
86 T-Type daily driver
Offline Be4u
« Reply #3 on: July 18 2005, 12:13:08 AM »
I took my new oil feed line and bent it and reshaped it. I think I did a hella good job for never bending tubing b4. Both ends line up perfectly! I'll post pics tomorrow.
Move to Canadia!
Offline Be4u
« Reply #4 on: July 18 2005, 07:37:31 PM »
heres a b4 and after.
Move to Canadia!
« Reply #5 on: July 18 2005, 10:16:04 PM »
Good job!
Offline 87natty
turbo oil feed line
« Reply #6 on: July 19 2005, 04:33:28 AM »
You stud.
Offline Recklessrob
« Reply #7 on: July 19 2005, 12:42:42 PM »
Looks good.  :atbeer:
Rob
Offline Be4u
« Reply #8 on: July 19 2005, 01:33:36 PM »
Thank you thank you! :yawinkle:
Move to Canadia!
