Author Topic: Fuse Box Wiring  (Read 3566 times)
Offline gordyzx9r
  • The Sultan of Swank
Fuse Box Wiring
« on: April 01 2009, 10:27:53 AM »
Just curious how people are powering their accessories.
I have the following that need power:
SMC Alcohol Control
Scanmaster
Tachometer
Casper's Audible Knock Alarm
I just realized that I have one of them plugged into a battery port and it must be causing a constant drain so I need to change that today.
As far as the IGN ports, is it alright to splice two accessories into one port?
Offline Recklessrob
Re: Fuse Box Wiring
« Reply #1 on: April 01 2009, 12:26:59 PM »
The scanmaster and audible knock just get ign power (very little draw)
As for the SMC kit you'll want to be a little more creative and set up a relay
for your pump. (probably included in the kit w/ directions)
Rob
Offline 87natty
Fuse Box Wiring
« Reply #2 on: April 01 2009, 03:06:16 PM »
Yup. I have an ANS knock alert and my Scanmaster hooked up to the IGN ports on the fuse box. I wouldn't splice two into one.
Fuse Box Wiring
« Reply #3 on: April 01 2009, 10:59:10 PM »
all the ign ports share a common fuse so it really does not make any difference.
Offline gordyzx9r
Re: Fuse Box Wiring
« Reply #4 on: April 02 2009, 08:53:53 AM »
Quote from: "Recklessrob @ Wed Apr 01, 2009 11:26 am"
I have a first generation (the non-progressive) SMC kit.  It was installed years ago and I don't think there is a relay, I think it's just getting it's power from the fuse box.  IDK for sure, I didn't install it.
As for the battery ports, if something is wired into a battery port will it cause a constant drain even with the key off?
Re: Fuse Box Wiring
« Reply #5 on: April 02 2009, 09:26:34 AM »
Quote from: "gordyzx9r @ Thu Apr 02, 2009 8:53 am"
It should not as long as it does not draw any current while the device is off.
