Don't be so afraid of the power master. Just remember one thing: With the key off (preferably a disconnected battery) pump the brake pedal 25 times to bleed off pressure from the accumulator before servicing any parts.
As for you light issue Is the L.E.D. bright enough to light up the factory light that you want? You may be able to drill out an old bulb socket to mount the L.E.D.
What is the problem with your brakes anyways ?
B. Turn ignition on and wait until motor shuts off.1. If motor doesn't self-cycle in 2 minutes without brake apply, proceed to (C).2. If motor does self-cycle, an internal booster leak requires replacing the Powermaster assembly.
