The Bastard Child Buick Board
Rolled up copy of Hiustler magazine in the crossover pipe?
I'll give a couple of more hints.Always lean on top end and when turbo first spools up. Never been able to get the turbo above 21lbs of boost, either tuner style or normal.Ok back under my rock.
Boost line install ?
Your boost gauge should've still told you what the actual boost was.
I was thinking the boost line to the wastegate.At least you have alky, so hopefully, you won't need headgaskets.
