Author Topic: Stainless steel fuel lines  (Read 8366 times)
Offline Recklessrob
« on: January 26 2008, 11:56:42 PM »
I'm looking for stainless steel fuel lines. Not the set that goes to the fuel rail, but
rather the lines to and from the fuel filter and the return line that runs along side them. Anyone ever seen these? Where?
Rob
Offline 87natty
« Reply #1 on: January 27 2008, 01:04:16 AM »
Shit, go to a liquor store, pick up an issue of Hot Rod. In the back they have the ads for a company that specializes in fuel lines. I wan tot say it's called Inline Tube or something. I think they even sell the multi-piece kits, so you don't have to take the damn body off the frame to get them in.
http://www.inlinetube.com/
Offline Recklessrob
Re: Stainless steel fuel lines
« Reply #2 on: January 27 2008, 02:12:20 AM »
That may be what I'm looking for. The listings are a little disheartening thoughh.
'83 to '87 all have the same turbo oil feed line
The list a V8 for the GN 3/8" feed line etc...
I guess I'd have to call them to make sure?
Rob
Offline Wrecked Em
    • http://www.hotairbuick.com
« Reply #3 on: January 27 2008, 02:30:17 PM »
http://www.classictube.com/
Try these guys. I have a friend that swears by them. He has used them on several GS's.
Offline chrisgarrett
« Reply #4 on: December 20 2010, 10:05:12 AM »
I've used ClassicTubes throughout my fuel system.
Offline firebird_1252
  • PSI: -1
« Reply #5 on: December 20 2010, 01:07:20 PM »
i just did all stainless from the fuel rail back.. not doing it again.  just the way i look at it.
87 GN- :D
« Reply #6 on: December 20 2010, 06:46:39 PM »
Anyone know where to get the little rubber brake hose that is above the rear end?  Maybe one in braided stainless?
Offline gordyzx9r
  • The Sultan of Swank
« Reply #7 on: December 20 2010, 07:57:02 PM »
Quote from: "chrisgarrett @ Mon Dec 20, 2010 10:05 am"
Offline WE4_Roller
« Reply #8 on: December 20 2010, 08:08:34 PM »
Russell makes that rear hose in braided steel teflon line.
I've only seen it available as part of a 3 hose kit that includes the two front rubber hose lines in braided stainless teflon as well.
About $80 for all 3.
Jegs, Summitt etc.
« Reply #10 on: December 20 2010, 09:55:09 PM »
Quote from: "gordyzx9r @ Mon Dec 20, 2010 7:57 pm"
Offline TRICKSIXPA
  • Shiny Parts Addict!
« Reply #11 on: December 20 2010, 10:22:55 PM »
The brakeline kit by Russell part#
692100 nice kit does not come with the
Banjo bolts you can reuse the stock ones.
 It does have the washers.
Stefan
  • PSI: -1
« Reply #12 on: December 20 2010, 10:40:12 PM »
chris try brian. i think he has them.
87 GN- :D
« Reply #13 on: December 21 2010, 07:02:38 PM »
thanks
Offline BigMike
  • Newbie
« Reply #14 on: December 24 2010, 09:10:02 AM »
I did my Limited and bought all the ss brake lines and all the ss fuel and return lines and ss vapor lines. I drove down to classic tube in Lancaster NY (about a 1 1/2 drive from me in Canada)
The guy I dealt with owns a Grand National and was very helpful(cant remember his name)
I ordered over the phone then went to pick them up. Make sure you have lots of room in your truck. Lines are long . Then I spent the next two days putting them on. Pain in the butt. I  replaced all the lines because someone bent the factory line at the fuel filter and replaced it with a rubber piece.This was before I owned it.
