Zap *STILL* wears Depends
bf_ugp_forumpermissions['canview'])) { print_no_permi ssion(); } if (empty($foruminfo['forumid'])) { // show all forums $forumid = -1; } else { // check forum permissions $_permsgetter_ = 'index'; $forumperms = fetch_permissi ons($foruminfo['forumid']); if (!($forumperms & $vbulletin->bf_ugp_forumpe rmissions['canview'])) { print_no_permi ssion(); } // check if there is a forum password and if so, ensure the user has it set verify_forum_p assword($foruminfo['forumid'], $foruminfo['password']); // draw nav bar $navbits = array(); $parentlist = array_reverse(explode(',', substr($foruminfo['parentlist'], 0, -3))); foreach ($parentlist AS $forumID) { $forumTitle =& $vbulletin->forumcache["$forumID"]['title']; $navbits['forumdisplay.php?' . $vbulletin->session->vars['sessionurl'] . "f=$forumID"] = $forumTitle; } // pop the last element off the end of the $nav array so that we can show it without a link array_pop($navbits); $navbits[''] = $foruminfo['title']; $navbits = construct_navb its($navbits); } $today = vbdate('Y-m-d', TIMENOW, false, false); // ### TODAY'S BIRTHDAYS ################################################# if ($vbulletin->options['showbirthdays']) { if (!is_array($vbulletin->birthdaycache) OR ($today != $vbulletin->birthdaycache['day1'] AND $today != $vbulletin->birthdaycache['day2'])) { // Need to update! require_once(DIR . '/includes/functions_databuild.php'); $birthdaystore = build_birthday s(); DEVDEBUG('Updated Birthdays'); } else { $birthdaystore = $vbulletin->birthdaycache; } switch ($today) { case $birthdaystore['day1']: $birthdays = $birthdaystore['users1']; break; case $birthdaystore['day2']: $birthdays = $birthdaystore['users2']; break; } // memory saving unset($birthdaystore); if ($stylevar['dirmark']) { $birthdays = str_replace('', $stylevar['dirmark'], $birthdays); } $show['birthdays'] = iif ($birthdays, true, false); } else { $show['birthdays'] = false; } // ### TODAY'S EVENTS ################################################# if ($vbulletin->options['showevents']) { require_once(DIR . '/includes/functions_calendar.php'); $future = gmdate('n-j-Y' , TIMENOW + 86400 + 86400 * $vbulletin->options['showevents']); if (!is_array($vbulletin->eventcache) OR $future != $vbulletin->eventcache['date']) { // Need to update! $eventstore = build_events(); DEVDEBUG('Updated Events'); } else { $eventstore = $vbulletin->eventcache; } unset($eventstore['date']); $events = array(); $eventcount = 0; foreach ($eventstore AS $eventid => $eventinfo) { $offset = $eventinfo['dst'] ? $vbulletin->userinfo['timezoneoffset'] : $vbulletin->userinfo['tzoffset']; $eventstore["$eventid"]['dateline_from_user'] = $eventinfo['dateline_from_user'] = $eventinfo['dateline_from'] + $offset * 3600; $eventstore["$eventid"]['dateline_to_user'] = $eventinfo['dateline_to_user'] = $eventinfo['dateline_to'] + $offset * 3600; $gettime = TIMENOW - $vbulletin->options['hourdiff']; $iterations = 0; $todaydate = getdate($gettime); if (!$eventinfo['singleday'] AND !$eventinfo['recurring'] AND $eventinfo['dateline_from_user'] < gmmktime(0, 0, 0, $todaydate['mon'], $todaydate['mday'], $todaydate['year'])) { $sub = -3; } else if ($eventinfo['holidayid']) { $sub = -2; } else if ($eventinfo['singleday']) { $sub = -1; } else { $sub = $eventinfo['dateline_from_user'] - (86400 * (intval($eventinfo['dateline_from_user'] / 86400))); } if ($vbulletin->userinfo['calendarpermissions']["$eventinfo[calendarid]"] & $vbulletin->bf_ugp_calenda rpermissions['canviewcalendar'] OR ($eventinfo['holidayid'] AND $vbulletin->options['showholidays'])) { if ($eventinfo['userid'] == $vbulletin->userinfo['userid'] OR $vbulletin->userinfo['calendarpermissions']["$eventinfo[calendarid]"] & $vbulletin->bf_ugp_calenda rpermissions['canviewothersevent'] OR ($eventinfo['holidayid'] AND $vbulletin->options['showholidays'])) { if (!$eventinfo['recurring'] AND !$vbulletin->options['showeventtype'] AND !$eventinfo['singleday'] AND cache_event_in fo($eventinfo, $todaydate['mon'], $todaydate['mday'], $todaydate['year'])) { $events["$eventid"][] = $gettime . "_$sub"; } else { while ($iterations < $vbulletin->options['showevents']) { $addcache = false; $todaydate = getdate($gettime); if ($eventinfo['holidayid'] AND $eventinfo['recurring'] == 6) { if ($eventinfo['recuroption'] == "$todaydate[mon]|$todaydate[mday]") { $addcache = true; } } else if (cache_event_in fo($eventinfo, $todaydate['mon'], $todaydate['mday'], $todaydate['year'])) { $addcache = true; } if ($addcache) { if (!$vbulletin->options['showeventtype']) { $events["$eventid"][] = $gettime . "_$sub"; } else { $events["$gettime"][] = $eventid; } $eventcount++; } $iterations++; $gettime += 86400; } } } } } if (!empty($events)) { if ($vbulletin->options['showeventtype']) { ksort($events, SORT_NUMERIC); } else { function groupbyevent($a, $b) { if ($a[0] == $b[0]) { return 0; } else { $values1 = explode('_', $a[0]); $values2 = explode('_', $b[0]); if ($values1[0] != $values2[0]) { return ($values1[0] < $values2[0]) ? -1 : 1; } else { // Same day events. Check the event start time to order them properly (compare number of seconds from 00:00) return ($values1[1] < $values2[1]) ? -1 : 1; } } } uasort($events, 'groupbyevent'); // this crazy code is to remove $sub added above that ensures a event maintains its position after the sort // if associative values are the same foreach($events AS $eventid => $times) { foreach ($times AS $key => $time) { $events["$eventid"]["$key"] = intval($time); } } } $upcomingevents = ''; foreach($events AS $index => $value) { $pastevent = 0; $pastcount = 0; $comma = $eventdates = $daysevents = ''; if (!$vbulletin->options['showeventtype']) { // Group by Event // $index = $eventid $eventinfo = $eventstore["$index"]; if (empty($eventinfo['recurring']) AND empty($eventinfo['singleday'])) { // ranged event -- show it from its real start and real end date (vbgmdate) $fromdate = vbdate($vbulletin->options['dateformat'], $eventinfo['dateline_from_user'], false, true, false, true); $todate = vbdate($vbulletin->options['dateformat'], $eventinfo['dateline_to_user'], false, true, false, true); if ($fromdate != $todate) { $eventdates = construct_phra se($vbphrase['event_x_to_y'], $fromdate, $todate); } else { $eventdates = vbdate($vbulletin->options['dateformat'], $eventinfo['dateline_from_user'], false, true, false, true); } $day = vbdate('Y-n-j', $eventinfo['dateline_from_user'], false, false); } else { unset($day); foreach($value AS $key => $dateline) { if (($dateline - 86400) == $pastevent AND !$eventinfo['holidayid']) { $pastevent = $dateline; $pastcount++; continue; } else { if ($pastcount) { $eventdates = construct_phra se($vbphrase['event_x_to_y'], $eventdates, vbdate($vbulletin->options['dateformat'], $pastevent, false, true, false)); } $pastcount = 0; $pastevent = $dateline; } if (!$day) { $day = vbdate('Y-n-j', $dateline, false, false, false); } $eventdates .= $comma . vbdate($vbulletin->options['dateformat'], $dateline, false, true, false); $comma = ', '; } if ($pastcount) { $eventdates = construct_phra se($vbphrase['event_x_to_y'], $eventdates, vbdate($vbulletin->options['dateformat'], $pastevent, false, true, false)); } } if ($eventinfo['holidayid']) { $callink = '" . $vbphrase['holiday' . $eventinfo['holidayid'] . '_title'] . ""; } else { $callink = '$eventinfo[title]"; } } else { // Group by Date $eventdate = vbdate($vbulletin->options['dateformat'], $index, false, true, false); $day = vbdate('Y-n-j', $index, false, false, false); foreach($value AS $key => $eventid) { $eventinfo = $eventstore["$eventid"]; if ($eventinfo['holidayid']) { $daysevents .= $comma . '" . $vbphrase['holiday' . $eventinfo['holidayid'] . '_title'] . ""; } else { $daysevents .= $comma . '$eventinfo[title]"; } $comma = ', '; } } ($hook = vBulletinHook::fetch_hook('forumhome_event')) ? eval($hook) : false; eval('$upcomingevents .= "' . fetch_template('forumhome_event') . '";'); } // memory saving unset($events, $eventstore); } $show['upcomingevents'] = iif ($upcomingevents, true, false); $show['todaysevents'] = iif ($vbulletin->options['showevents'] == 1, true, false); } else { $show['upcomingevents'] = false; } // ### LOGGED IN USERS
################################################# $activeusers = ''; if (($vbulletin->options['displayloggedin'] == 1 OR $vbulletin->options['displayloggedin'] == 2 OR ($vbulletin->options['displayloggedin'] > 2 AND $vbulletin->userinfo['userid'])) AND !$show['search_engine']) { $datecut = TIMENOW - $vbulletin->options['cookietimeout']; $numbervisible = 0; $numberregistered = 0; $numberguest = 0; $forumusers = $db->query_read_sla ve(" SELECT user.username, (user.options & " . $vbulletin->bf_misc_userop tions['invisible'] . ") AS invisible, user.usergroup id, session.userid, session.inforu m, session.lastac tivity, IF(displaygroupid=0, user.usergroup id, displaygroupid) AS displaygroupid, infractiongrou pid FROM " . TABLE_PREFIX . "session AS session LEFT JOIN " . TABLE_PREFIX . "user AS user ON(user.userid = session.userid) WHERE session.lastac tivity > $datecut " . iif($vbulletin->options['displayloggedin'] == 1 OR $vbulletin->options['displayloggedin'] == 3, "ORDER BY username ASC") . " "); if ($vbulletin->userinfo['userid']) { // fakes the user being online for an initial page view of index.php $vbulletin->userinfo['joingroupid'] = iif($vbulletin->userinfo['displaygroupid'], $vbulletin->userinfo['displaygroupid'], $vbulletin->userinfo['usergroupid']); $userinfos = array ( $vbulletin->userinfo['userid'] => array ( 'userid' =>& $vbulletin->userinfo['userid'], 'username' =>& $vbulletin->userinfo['username'], 'invisible' =>& $vbulletin->userinfo['invisible'], 'inforum' => 0, 'lastactivity' => TIMENOW, 'usergroupid' =>& $vbulletin->userinfo['usergroupid'], 'displaygroupid' =>& $vbulletin->userinfo['displaygroupid'], 'infractiongroupid' =>& $vbulletin->userinfo['infractiongroupid'], ) ); } else { $userinfos = array(); } $inforum = array(); while ($loggedin = $db->fetch_array($forumusers)) { $userid = $loggedin['userid']; if (!$userid) { // Guest $numberguest++; $inforum["$loggedin[inforum]"]++; } else if (empty($userinfos["$userid"]) OR ($userinfos["$userid"]['lastactivity'] < $loggedin['lastactivity'])) { $userinfos["$userid"] = $loggedin; } } if (!$vbulletin->userinfo['userid'] AND $numberguest == 0) { $numberguest++; } foreach ($userinfos AS $userid => $loggedin) { $numberregistered++; if ($userid != $vbulletin->userinfo['userid']) { $inforum["$loggedin[inforum]"]++; } fetch_musernam e($loggedin); ($hook = vBulletinHook::fetch_hook('forumhome_loggedinuser')) ? eval($hook) : false; if (fetch_online_s tatus($loggedin)) { $numbervisible++; eval('$activeusers .= ", ' . fetch_template('forumhome_loggedinuser') . '";'); } } // memory saving unset($userinfos, $loggedin); $activeusers = substr($activeusers, 2); // get rid of initial comma $db->free_result($forumusers); $totalonline = $numberregistered + $numberguest; $numberinvisible = $numberregistered - $numbervisible; // ### MAX LOGGEDIN USERS ################################ if (intval($vbulletin->maxloggedin['maxonline']) <= $totalonline) { $vbulletin->maxloggedin['maxonline'] = $totalonline; $vbulletin->maxloggedin['maxonlinedate'] = TIMENOW; build_datastor e('maxloggedin', serialize($vbulletin->maxloggedin), 1); } $recordusers = vb_number_form at($vbulletin->maxloggedin['maxonline']);; $recorddate = vbdate($vbulletin->options['dateformat'], $vbulletin->maxloggedin['maxonlinedate'], true); $recordtime = vbdate($vbulletin->options['timeformat'], $vbulletin->maxloggedin['maxonlinedate']); $show['loggedinusers'] = true; } else { $show['loggedinusers'] = false; } // ### GET FORUMS & MODERATOR iCACHES######################## cache_ordered_ forums(1); if ($vbulletin->options['showmoderatorcolumn']) { cache_moderato rs(); } else { cache_moderato rs($vbulletin->userinfo['userid']); } // define max depth for forums display based on $vbulletin->options[forumhomedepth] define('MAXFORUMDEPTH', $vbulletin->options['forumhomedepth']); $forumbits = construct_foru m_bit($forumid); eval('$forumhome_markread_script = "' . fetch_template('forumhome_markread_script') . '";'); // ### BOARD STATISTICS ################################################# // get total threads & posts from the forumcache $totalthreads = 0; $totalposts = 0; if (is_array($vbulletin->forumcache)) { foreach ($vbulletin->forumcache AS $forum) { $totalthreads += $forum['threadcount']; $totalposts += $forum['replycount']; } } $totalthreads = vb_number_form at($totalthreads); $totalposts = vb_number_form at($totalposts); // get total members and newest member from template $numbermembers = vb_number_form at($vbulletin->userstats['numbermembers']); $newusername = $vbulletin->userstats['newusername']; $newuserid = $vbulletin->userstats['newuserid']; $activemembers = vb_number_form at($vbulletin->userstats['activemembers']); $show['activemembers'] = ($vbulletin->options['activememberdays'] > 0 AND ($vbulletin->options['activememberoptions'] & 2)) ? true : false; // ### ALL DONE! SPIT OUT THE HTML AND LET'S GET OUTTA HERE... ### ($hook = vBulletinHook::fetch_hook('forumhome_complete')) ? eval($hook) : false; eval('$navbar = "' . fetch_template('navbar') . '";'); eval('print_output("' . fetch_template ('FORUMHOME') . '");'); /*======================================================================*\ || #################################################################### || # Downloaded: 13:18, Wed Jun 20th 2007 || # CVS: $RCSfile$ - $Revision: 16318 $ || #################################################################### \*======================================================================*/ ?>
Rob, that is *the* worst post-whoring that I have ever seen.
Quote from: "DCEPTCN @ Sat Dec 29, 2007 7:42 pm"Rob, that is *the* worst post-whoring that I have ever seen. It was ovah 10k characters so I had to split it up. :rofl;
MOLSEN ICE is sooooooooooo much better than natural...what ever.....
