Author Topic: New toy for the wife  (Read 5206 times)
Offline Ttype83
« on: July 03 2007, 09:24:13 AM »
Smoked her a$$ too  She had to eat buick burnout
Well it's her toy that I get to work on
1980 Corvette with a L48 auto (she can't drive a stick) 133k miles Runs good but needs some work. I got it for less than the 86 before all the parts. It needs new seals, door panels, carpet, driver seat cover and odds and ends. Off to get tune up stuff and vac lines. (If I don't have enough to work on) Can you tell she's happy..that's what really matters  :supz:
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Offline Recklessrob
Re: New toy for the wife
« Reply #1 on: July 03 2007, 01:07:56 PM »
Yeah, they're fun to work on, but they can't touch a Buick.
...and color coordination is a must.
http://www.ihadav8.com/phpBB2/download.php?id=963
Rob
Offline Ttype83
« Reply #2 on: July 04 2007, 11:37:50 AM »
Quote from: "Recklessrob @ Tue Jul 03, 2007 12:07 pm"
Yes Color coordination is a must..
I think it has a 84 engine block in it, the brown valve covers and dip stick is on the right side. Changed a bunch of vac lines, changed the oil and put a new air cleaner on it. Still need to do the tune up but that'll have to wait untill I got back home in a couple of weeks.
CarbedHotAir Slug
Offline straycat990
  • Buickless and Loving It!!!
« Reply #3 on: July 04 2007, 01:05:00 PM »
congrats on the vette.  http://forums.corvetteforum.com can be a great help in working on it. There are a lot of knowledgeable people there.  If you run into any problems on anything just pm me and I will try to help ya out. C3s are fun but very fickle creatures.
Offline Ttype83
« Reply #4 on: July 04 2007, 01:24:20 PM »
Quote from: "straycat990 @ Wed Jul 04, 2007 12:05 pm"
CarbedHotAir Slug
Offline straycat990
« Reply #5 on: July 04 2007, 03:22:13 PM »
ah heater probs ... well easiest way to access the vac lines to the heater is to remove the glove box insert.  you will see them located above the upper right corner of the heater box. there is a vac tee that has a nasty habit of coming loose and that could be your problem.  As for headlights ..most likely either the coffee can vac chamber is full of pin holes or the actuators seals have dry rotted.  Coffee can is located infront the radiator.  Btw once you get the vac to the actuator there is an over ride switch located below the steering column to check also .. pull the knob down and the headlights will always stay up ...no matter if the headlights are on or not.
DCEPTCN
  • Guest
« Reply #6 on: July 04 2007, 04:01:29 PM »
You know, with a title like that I wasn't sure if I wanted to open this thread.
Nice car, though!
Offline Ttype83
« Reply #7 on: July 04 2007, 04:06:50 PM »
Yep found the override switch yesterday, well have the owners manual and was wonder what it was for. I thought going thru the glovr box would be best...thanks  :supz:
DCEPTCN I thought ou would open anything...lol
and you hadn't seen pics of the inside..sheesh another money pit.
CarbedHotAir Slug
Offline straycat990
« Reply #8 on: July 04 2007, 06:52:41 PM »
oops ..my bad ..upper left side for the vac lines
Offline Be4u
« Reply #9 on: July 05 2007, 03:24:17 AM »
Uh-oh Jim. Shes going to try and get revenge after you get the vette straightened up. Good luck to her! :rofl;
Save the bumper fillers!
Move to Canadia!
Offline Ttype83
« Reply #10 on: July 05 2007, 06:25:26 PM »
Quote from: "Be4u @ Thu Jul 05, 2007 2:24 am"
The 83 is her best bet  :rofl;
CarbedHotAir Slug
Offline straycat990
« Reply #11 on: July 05 2007, 06:53:11 PM »
Quote from: "Ttype83 @ Thu Jul 05, 2007 5:25 pm"
Offline 87natty
« Reply #12 on: July 05 2007, 11:25:38 PM »
If I didn't score my GN, I was going to buy a '79 Vette. If i didn't liek that, I had my eyes on a 72 Charger, 4 speed 440.
I have to say I love the flares on that generation of Corvettes.
Offline Be4u
« Reply #13 on: July 05 2007, 11:46:17 PM »
I just had a funny thought, Jims wife + the  burnouts she loves to do = lots of money spent on tires.
Move to Canadia!
Offline Recklessrob
« Reply #14 on: July 05 2007, 11:53:27 PM »
Quote from: "Be4u @ Thu Jul 05, 2007 10:46 pm"
Rob
