Author Topic: Powermaster took a crap  (Read 6134 times)
Offline Ttype83
« on: June 13 2007, 10:29:02 PM »
Driving to the airport a little over a week ago and it took a crap....now it's park at home. Well I guess I can replace the valve springs and passenger moyor mount while it's down  :mad:
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Offline Wrecked Em
    • http://www.hotairbuick.com
Re: Powermaster took a crap
« Reply #1 on: June 13 2007, 11:42:57 PM »
Sorry to here about troubles Jim.
 I do not have a single Powermaster in the fleet and have had zero brake issues. I may have a vacuum setup for sale in a week. Let me know if you are interested.
Offline Recklessrob
« Reply #2 on: June 14 2007, 01:41:34 AM »
Jim, what are your symptoms with the Powermonster?
Rob
« Reply #3 on: June 14 2007, 10:20:40 AM »
Vacuum conversion!!!!!!!!!!!!
Offline Ttype83
« Reply #4 on: June 14 2007, 10:35:20 AM »
Quote from: "Recklessrob @ Thu Jun 14, 2007 12:41 am"
It first started as a soft pedal then moved on to the motor clcying every 4-8sec and the power side of the Mastercylinder would leak down with in 20 minutes of the key being off. So it started as a O ring leak. I think the motor just gets hot and shuts down. It hasn't blown a fuse yet, but the motor stops working for a period of time then will work again for about 2 minutes...gett ing shorter everytime I start the cah.
I like the powermoster system...I like the hydroboost best, but converting is $$$$$
I'm not a fan of vacuum brakes, I know it's the cheapest route. But the PM work for over 20 years before giving out...and I didn't really know how to work on it when I first got it...so I'm sure I helped it along  :mad:
CarbedHotAir Slug
DCEPTCN
  • Guest
« Reply #5 on: June 14 2007, 04:30:16 PM »
Of course it did...they all crap out. I'm not recommending the vacuum conversion, though.
« Reply #6 on: June 14 2007, 05:40:15 PM »
My vac brakes work great!  Of course I do have Baer discs all the way around. :supz:
DCEPTCN
  • Guest
« Reply #7 on: June 14 2007, 06:51:18 PM »
Mine never worked right....even after repeated bleeds, an new cylinder, yadda, yadda. I'm planning to get a transbrake because my vacuum brake set up can't hold but 4 or 5 lbs of boost.
Offline straycat990
  • Buickless and Loving It!!!
« Reply #8 on: June 14 2007, 07:20:36 PM »
what rear brake linings do you have ... if you bought metalic then I can understand why you can only hold 5 psi.  You need the cheap shoes, they will bite harder but they don't last too long. that is the down side to them ..along with alot more brake dust.
Offline Wrecked Em
« Reply #9 on: June 14 2007, 08:02:26 PM »
Quote from: "straycat990 @ Thu Jun 14, 2007 5:20 pm"
Offline Ttype83
« Reply #10 on: June 15 2007, 09:16:00 AM »
Quote from: "Wrecked Em @ Thu Jun 14, 2007 7:02 pm"
I like Hydroboost the best. A lot of cars had them, I believe even the diesels. You may be able to scrounge one up at the boneyard.
I may just have to go junk-in  :supz:
The 83 has the hydro's, it'll hold 10 psi with slicks and still has the orginal rear brakes on it.
CarbedHotAir Slug
Offline Recklessrob
« Reply #11 on: June 18 2007, 12:55:54 AM »
That'd be a dofferent fix...
Rob
Offline Ttype83
« Reply #12 on: June 20 2007, 10:28:48 AM »
Quote from: "Recklessrob @ Sun Jun 17, 2007 11:55 pm"
That's the way we roll
CarbedHotAir Slug
Offline Recklessrob
« Reply #13 on: June 20 2007, 12:24:51 PM »
Quote from: "Ttype83 @ Wed Jun 20, 2007 9:28 am"
Rob
Offline Ttype83
« Reply #14 on: June 21 2007, 08:39:36 AM »
$358.88 plus tax, there is a $50 core charge too
CarbedHotAir Slug
