General
IHADAV8 Playground
Got booted from the track last night
Topic: Got booted from the track last night (Read 1777 times)
Ttype83
Turbo Street Modified
April 28 2007, 04:44:12 PM »
Seems I have gotten a few trans leaks, I only got one run in. They saw the leak and didn't look that bad and let me go. Someone blow a engine and shut the track down for at least 40 minutes. I tighted down a loose line by the rad and staged...Got booted...
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Top Speed
Don't Tread on Me
PSI: -2
April 29 2007, 09:36:46 AM »
That sucks. How did the one run go?
Champion Irons w/T&D roller rockers, TA-61 turbo, 206/206 Comp Cam, 57 lb/hr Siemens Injectors, 3000 stall PTC, PTE Plenum w/RJC Power Plate, 70 mm Accufab Throttle Body, RJC 325 Megacooler, TurboTweak 5.7/ Alky Control w/M1 methanol, 23 psig on the street, Puddn' Power engine, Borla Exhaust
Ttype83
Re: Got booted from the track last night
April 29 2007, 01:34:29 PM »
Crappie, a good 60' for the dunlaps tho
1.966 60' , 5.569 330' , 8.714 @ 78.53 1/8, 11.436 1000' , 13.798 @ 94.24 ET
Started out strong then fell flat on the upper rpm's. dn't a couple of changes but did get to see if it helped. MPH is a little low for the ET. Crawling under car today to find the leak.
CarbedHotAir Slug
Recklessrob
April 30 2007, 12:24:53 AM »
You'll get it straightened out. :supz:
Rob
General
IHADAV8 Playground
