Author Topic: Biggest Turbo ?  (Read 10977 times)
Offline Ttype83
Biggest Turbo ?
« on: April 16 2007, 12:16:41 AM »
OK, just daydreaming... working nights for the next 4 days....
OK, stretch IC, 2800 stall 12" and 50lb injectors.
What's the max turbo (I like the 44's) but may wish to push it a tad faster.
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Offline 87natty
Biggest Turbo ?
« Reply #1 on: April 16 2007, 01:38:14 AM »
I want to say you can easily push a 51 with that setup. 12" 2800 Pat's? I love that converter. Got the same one in my GN, but with a stock turbo. Been beating on it (converter) for 3 years or so now, daily driven, no issues.
Offline Recklessrob
Re: Biggest Turbo ?
« Reply #2 on: April 16 2007, 02:41:25 AM »
A 44 will work with a stock torque converter. I'd bet a TE-60 would work nicely
for the same price as a 44.
Rob
Offline Ttype83
Re: Biggest Turbo ?
« Reply #3 on: April 16 2007, 03:32:56 AM »
Also looking at the GT 6152 E, which replaces the 50's
CarbedHotAir Slug
Offline 87natty
Biggest Turbo ?
« Reply #4 on: April 16 2007, 04:36:35 AM »
I dig those ball bearing Garrett's. That's what is it right?
Offline Ttype83
Re: Biggest Turbo ?
« Reply #5 on: April 16 2007, 04:50:48 AM »
No not want I can find. You can get a 44 in BB or a GT6131
My think Rob is right a CPTE-60 from Jack would be the max for my stall and the same price.
CarbedHotAir Slug
Offline straycat990
  • Buickless and Loving It!!!
Biggest Turbo ?
« Reply #6 on: April 16 2007, 08:38:27 AM »
I ran at one time a T 70 p trim bb turbonetics turbo with a 2800 converter. Thing spooled like crazy .. now of course you will need some bigger injectors than 50s.  One other thing I did was to use a garrett turbine housing over the pte one.  Only one thing can be said though ...ball bearing turbos rule!
Offline Wrecked Em
    • http://www.hotairbuick.com
Re: Biggest Turbo ?
« Reply #7 on: April 16 2007, 02:03:39 PM »
A 52 or 54 may be a good choice.
DCEPTCN
  • Guest
Biggest Turbo ?
« Reply #8 on: April 16 2007, 02:57:34 PM »
Quote from: "87natty @ Sun Apr 15, 2007 10:38 pm"
I can't wait to hear from you when you put that 51 in....have space in your luggage for it! At sea level you should have plenty of stall for it.
Offline ledzeppac
Biggest Turbo ?
« Reply #9 on: April 16 2007, 06:11:32 PM »
I wouldn't go bigger than a t62-ish with a 2800 stall.  Throw in a boost valve and it will spool decently.
Offline Ttype83
Biggest Turbo ?
« Reply #10 on: April 16 2007, 06:14:38 PM »
Quote from: "straycat990 @ Mon Apr 16, 2007 7:38 am"
CarbedHotAir Slug
Offline 87natty
Biggest Turbo ?
« Reply #11 on: April 16 2007, 11:17:16 PM »
Quote from: "DCEPTCN @ Mon Apr 16, 2007 10:57 am"
Do you want me to call you during or after morning wood?
Offline straycat990
Biggest Turbo ?
« Reply #12 on: April 16 2007, 11:37:54 PM »
Quote from: "Ttype83 @ Mon Apr 16, 2007 5:14 pm"
I know of at least one that has failed at 9k miles and a dozen or so passes.
I'll wait them out a little longer. But I'm really suprised that on some of the choices with only a 2800 stall and 50s...oh I have alky too.
I had not heard of any short lived turbonetic bb turbos .. have heard of several pte/ garrett ones dying. But, they are different turbos, pte/ garrett is a dual bb where as the turbonetic's is only bb on the cool side.
Since you are lookin to stay with 50# injectors .. I would look to a small p trim turbo. maybe a te-63, but nothing larger than that.  that will get you into the low 11's easily with some c16, or low 12's on pump gas and 17 to 18 psi boost.
As for spool up with bb turbos,  my last set up was a t-72 turbonetics bb p trim .. got it off old buzzard  in Atlanta, Ga.  that turbo was on a girdled 109, champ iron heads, ported intake, and a speed pro 214 cam.  I could wack the throttle in park and get 3 psi on the boost gauge.  Which ever turbo you choose ...go with the bb option. You won't regret it.
Offline Recklessrob
Re: Biggest Turbo ?
« Reply #13 on: April 16 2007, 11:56:05 PM »
Some more food for thought...
With the BB turbo, you'll need to add water lines to cool it.
And they're very pricey. If you're willing to meet that criteria, BB
is the way to go. :supz:
Rob
Offline straycat990
Biggest Turbo ?
« Reply #14 on: April 17 2007, 07:07:57 AM »
RR the T-netics does not require water cooling. The PTE/Garrett may very well since it's a dual bb turbo.
